I am sorting through some run errors in an Openstudio 2.8.1 model and trying to troubleshoot them:
GetHTSurfaceData: Surfaces with interface to Ground found but no "Ground Temperatures" were input.
However, I've verified the weather file is loaded.
ProcessScheduleInput: Schedule:Day:Interval="Schedule Day 1", Bland schedule...---will not be validated.
I've not seen this error before.
RoofCeiling:Detailed, Vertex size mismatch. I've ran the diagnostic script and no errors encountered. (Two separate ones like this)
GetHTSubSurfaceData: Surface Openings have too much area for base surface. As previously mentioned, I've run the diagnostic script.
I have another surface with negative surface area.
Not sure how to resolve these.
Link to model: https://www.dropbox.com/s/mj5w2dlcrhxgn9c/190819_zones_named_plusthermostats.osm?dl=0
I'm using Austin TMY3 file.
