Set Window to Wall Ratio in Sketchup fails
I'm modeling a building with OpenStudio that has a lot of glazing according to Appendix G, so for the baseline I need to reset the window to wall ratio to 0.4. Seems like a perfect application to leverage the User Script "Set Window to Wall Ratio".
The problem I'm getting is that it doesn't do anything on my model, even if I try on very simple zones like the following.
Example of one zone
One I select the outdoor surface and apply the measure, nothing changes:
Surface selected
One thing is that, if I create a new space in my model and put a cube in there, the "Set Window to Wall Ratio" user script works like a charm on this.
Can someone offer a clue as to why it doesn't work?
Example of one zone
Surface selected
Update: Here is the link to the problematic OSM File if someone can take a look
Example of one zone
Surface selected
Example of one zone
Surface selected
