I tried running two Open Studio Models with Radiance Measure and I always get the same running error.
The first model had a complex geometry that was prepared in Sketchup with one space, two Daylight controls and an Illuminance map. The second model was a simple rectangular space with a Daylight control prepared from within Open Studio. In both cases, I get the same error.
I double-checked to make sure the model was complete to run Radiance.
The directory structure it is looking for does not exist on my computer. C:/Users/Hugues Rivard/AppData/Local/Temp/OpenStudioApp.k13596/resources/run/000_RadianceMeasure/radiance/options/treg.opt
I tried changing the "My Measures Directory" in the Preferences pull-down menu to "C:/openstudio-2.8.0/Measures"
I am a beginner in using Open Studio and I am at a lost on how to proceed and correct the error.
The Open Studio Model files for the simple example are available here: https://wetransfer.com/downloads/78c5d5538198bdf0c323415858f65a1820190806203302/3f024fce2182806c7b0957cbc498068220190806203302/a13e9a
Here is the error message I get:
Initializing workflow.
Processing OpenStudio Measures.
Applying RadianceMeasure
Result: Fail
Error: No such file or directory @ rb_sysopen - C:/Users/Hugues Rivard/AppData/Local/Temp/OpenStudioApp.k13596/resources/run/000_RadianceMeasure/radiance/options/treg.opt
eval:353:in initialize'
eval:353:inopen'
eval:353:in open'
C:/Users/Hugues Rivard/AppData/Local/Temp/OpenStudioApp.k13596/resources/measures/RadianceMeasure/measure.rb:736:inrun'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:467:in apply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:74:inblock in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:in each_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:inapply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_os_measures.rb:52:in perform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:instep'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in run'
:/openstudio_cli.rb:937:inexecute'
:/openstudio_cli.rb:726:in execute'
:/openstudio_cli.rb:1703:in<main>'
eval:110:in eval'
eval:110:inrequire_embedded_absolute'
eval:95:in block in require'
eval:89:ineach'
eval:89:in require'
eval:2:in<main>'
Info: Begin Encoding.default_external = UTF-8
Info: Begin Encoding.default_internal =
Info: Radiance multiprocessing features are not supported on Windows.
Info: Using 1 core(s) for Radiance jobs
Info: Found Radiance at: C:\openstudio-2.8.0\Radiance
Info: Found Perl at: C:\openstudio-2.8.0\Perl\perl\bin
Info: Found EnergyPlus at: C:\openstudio-2.8.0\EnergyPlus\energyplus.exe
Info: Radiance version: NREL 5.0.a.12 (by googs 2016.10.04) based on RADIANCE 5.0 Official Release by G. Ward
Info: Radiance binary dir: C:\openstudio-2.8.0\Radiance\bin
Info: Radiance library dir: C:\openstudio-2.8.0\Radiance\lib
Info: Translating OpenStudio 2.x model to Radiance format...
Info: OpenStudio CLI version: 2.8.0.55665635f0
Failed.
