Does the OS:AirTerminal:SingleDuct:InletSideMixer provide any outside air control for the zone?
I'm trying to model a DOAS system with four pipe fan coils and osa/return air mixing before supply to the fan coils, using this configuration.
When I check the primary airflow for the inlet mixer, it does not seem to control for minimum outside air for the zone.
The four pipe fan coil object only provide maximum osa input and schedule.
My question is how can I model the system to make sure that the DOAS unit delivers minimum required outside air cfm to the zone? I'm using the latest openstudio v2.8.1.
