Hey guys,
I'm working in OpenStudio 2.8.0. and SketchUp 2017 version 17.2.2555. I created my geometries in Sketchup before moving on to create my constructions, zones, systems. When I went to run the model I had failures relating to "degenerate" surfaces. From reading other posts here, I learned I needed to go back and edit m geometries to tighten them up. However, when I try to open the OSM through the Sketchup plugin I get this error for multiple surfaces: "Sub Surface 2 This sub surface's base surface 'Surface 503' does not have a face polygon, it cannot be drawn." I click ok and nothing pops up. However, I open the model inspector and everything pops up in there. On other posts I read that they would appear if they double click on an element in the inspector, but mine will not produce that. It just stays blank.
I did already try and uninstall/reinstall both softwares. If anyone thinks they might have a lead, I would appreciate it. Or if you need more info, let me know.
