Any easy method to change plant loop configuration in exidf file?
I received expidf file and need to modify plant loop configuration. I know it is possible to change plant loop configuration in expidf file but really difficult using IDF editor. Are there any easy method to modify plant loop configuration in expidf file? (e.g. method to import to OpenStudio etc)
