Hello,
I am trying to model a building that includes a fan coil system, make-up air units and exhaust fans.
I tried including the exhaust fans as zone equipment (OS:Fan:ZoneExhaust) but had balancing issues because the max air flow rate requires a hard entered number and the rest of the system id being auto sized.
Currently I have an air loop attached to the zones which I'm using as both the MAUs and the exhaust fans. Is this the correct way to model this system? I know that there are some similar threads but there has been updates that may have increased the functionality for this issue.
I have attached a link to the model here
This is just a Test model that im using to test out the system design.
