Hello Unmet,
Is there a reason that the Design of Experiments algorithm is not working? I keep receiving the following error when I attempt to leverage this technique in a PAT Algorithmic Mode. Thank you for any insight.
[1] "starting doe" Error in library(DoE.base) : there is no package called 'DoE.base'
