Slab objects used in the DOE prototype models
From a very good answer from this post, I got some background on the DOE prototype models, documentation, and the idf files.
I have a problem though. The Site:GroundTemperature:BuildingSurface and Site:WaterMainsTemperature objects appear to have been generated with Slab for each location. Tucson and Tampa pictured below for the Warehouse model.
But only the output objects of Slab, which are the two objects in the image, were saved in each idf file and not the Slab objects used to create them. This is a big problem because the materials used in the building slab are used in the Slab preprocessor, and I have no idea what all the objects are for these models. There are also basements in some of the models which is even more complicated than the object needed for a slab.
There is a comment in the idf file referring to a file location for generating these objects,
! Ground temperature object produced by /projects/bigsim/bin/gt2idf /projects/bigsim/comstd/_p.gtp/_p.gtp_copy_from_local/slab/output/Zone2B_semiheated_R0_0ftV_Warehouse_Tucson_STD2016.gtp
but I don't know how to access them.
There is a contact email from this webpage that I tried,
but I am yet to receive a reply.
Does anyone have access to the Slab objects referred to in the idf file comments?
The two files I ran the diff on can be downloaded here.
But only the output objects of Slab, which are the two objects in the image, were saved in each idf file and not the Slab objects used to create them. This is a big problem because the materials used in the building slab are used in the Slab preprocessor, and I have no idea what all the objects are for these models. There are also basements in some of the models which is even more complicated than the object objects needed for a slab.
But only the output objects of Slab, which are the two objects in the image, were saved in each idf file and not the Slab objects used to create them. This is a big problem because the materials used in the building slab are used in the Slab preprocessor, and I have no idea what all the objects are for these models. There are also basements in some of the models which is even more complicated than the objects needed for a slab.
