I'm trying to remove some four pipe active beams in openstudio v2.6 and have the following issues:
1). when i try to remove directly in openstudio by clicking the x button for the beam object at zone level, the program gives this error "unhandled exception" error.
2). when i try to remove it via openstudio measure, using equipment.remove. The program throws the following advanced output for the error:
[BOOST_ASSERT] Assertion wo failed on line 244 of class std::vector > __cdecl openstudio::model::detail::ZoneHVACEquipmentList_Impl::equipmentInCoolingOrder(void) in file C:\Git\OS\openstudiocore\src\model\ZoneHVACEquipmentList.cpp.
[10:22:40.833915 ERROR] Found error in state 'translator' with message ["Access violation - no RTTI data!::/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/model.rb:66:in translateModel'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/model.rb:66:intranslate_to_energyplus'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_translation.rb:54:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in run'\n:/openstudio_cli.rb:848:inexecute'\n:/openstudio_cli.rb:639:in execute'\n:/openstudio_cli.rb:1614:in'\neval:107:in eval'\neval:107:inrequire_embedded_absolute'\neval:92:in block in require'\neval:86:ineach'\neval:86:in require'\neval:2:in'"]}
Standard Error: [BOOST_ASSERT] Assertion wo failed on line 244 of class std::vector > __cdecl openstudio::model::detail::ZoneHVACEquipmentList_Impl::equipmentInCoolingOrder(void) in file C:\Git\OS\openstudiocore\src\model\ZoneHVACEquipmentList.cpp.
run.log:
3). when i use the "enable ideal air loads for all zones" measure, it also throws this unhandled exception
Anyone knows what might cause this error? Same happens in OpenStudio v2.7.
