Program Version,EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2019.01.21 17:02,IDD_Version 8.5.0 *** Beginning Zone Sizing Calculations * Warning * Weather file location will be used rather than entered (IDF) Location object. * ~~~ * ..Location object=ATLANTA-HARTSFIELD.JACKSON.INTL.AP_GA_USA WMO=722190 * ~~~ * ..Weather File Location=DAEJEON - KOR IWEC2 WMO#=471330 * ~~~ * ..due to location differences, Latitude difference=[2.73] degrees, Longitude difference=[211.80] degrees. * ~~~ * ..Time Zone difference=[14.0] hour(s), Elevation difference=[77.00] percent, [241.00] meters. * Warning * CheckUsedConstructions: There are 121 nominally unused constructions in input. * ~~~ * For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings; * Warning * ManageSizing: For a system sizing run, there must be at least 1 Sizing:System object input. SimulationControl System Sizing option ignored. *** Beginning Plant Sizing Calculations * Severe * For autosizing of Branch AIRLOOP G SW MAIN BRANCH, a system sizing run must be done. * ~~~ * No "Sizing:System" objects were entered. * Fatal * Program terminates due to previously shown condition(s). ...Summary of Errors that led to program termination: ..... Reference severe error count=1 ..... Last severe error=For autosizing of Branch AIRLOOP G SW MAIN BRANCH, a system sizing run must be done. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages.
*** ===== Final Error Summary ===== *** The following error categories occurred. Consider correcting or noting. *** Nominally Unused Constructions *** ..The nominally unused constructions warning is provided to alert you to potential conditions that can cause *** ..extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm *** ..object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
*** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 3 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 3 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 28.97sec
