EnergyPlus Version Conversion (8.5->8.6) fails at Ubuntu 18.04
Hi,
I am trying to convert EnergyPlus IDF version conversion in Ubuntu 18.04. I heard from a person that this is the right place to ask questions related to E+ version conversion.
Here's the command I used:
~/tools/EnergyPlus-9-1-0/PreProcess/IDFVersionUpdater/Transition-V8-5-0-to-V8-6-0 ~/tools/EnergyPlus-8-5-0/ExampleFiles/1ZoneDataCenterCRAC_wPumpedDXCoolingCoil.id
The versions are obvious in the command. However, I receive this message:
* Severe * IP: IDF line~1207 Did not find "Output:Variable" in list of Objects
* Severe * IP: IDF line~1209 Did not find "Output:Variable" in list of Objects
* Severe * IP: IDF line~1211 Did not find "Output:Variable" in list of Objects
* Severe * IP: IDF line~1216 Did not find "EnergyManagementSystem:Sensor" in list of Objects
* Severe * IP: IDF line~1221 Did not find "EnergyManagementSystem:Sensor" in list of Objects
* Severe * IP: IDF line~1226 Did not find "EnergyManagementSystem:OutputVariable" in list of Objects
* Severe * IP: IDF line~1234 Did not find "EnergyManagementSystem:GlobalVariable" in list of Objects
* Severe * IP: IDF line~1237 Did not find "EnergyManagementSystem:Program" in list of Objects
* Severe * IP: IDF line~1241 Did not find "Output:Variable" in list of Objects
* Severe * Possible incorrect IDD File
* ~~~ * Possible Invalid Numerics or other problems
At line 1233 of file /home/el/EnergyPlus/src/Transition/CreateNewIDFUsingRulesV8_6_0.f90
Fortran runtime error: Index '0' of dimension 1 of array 'idfrecords' below lower bound of 1
I'd appreciate if I can learn any hints related to this.
Thanks!
Hi,
Thanks!
Hi,
Thanks!
