Hi,
I am using Open Studio + sketchup to model a small commercial building.
I added the circular skylights to the roof surface of the model in sketchup and they are assigned as Skylight surfaces.
In open studio, I have added a construction assembly for the skylights.
I am able to simulate a model but when I look at the Energy Plus results, it doesn't seem to recognize the skylights as an exterior fenestration. The roof to skylight ratio is also 0%.
So I've also tried running the model without the skylights and there is no change in the results.
I'm not sure what I'm doing wrong but I don't feel confident that the skylights are being accounted for.
Any advice would be much appreciated. I've looked through past posts etc and haven't found any answers.
Thank you!
