Dear all,
I have a problem in compliling BCVTB and specifically in fortran example f90 -room. The line with the problem is line 29 of file build.xml in folder bcvtb/examples/f90-room which is related to link section of the file:
<target name="link" depends="compile" if="have.ifort" description="Links binaries">
<exec executable="ifort" failonerror="true" osfamily="unix">
<arg line="-o f90client f90client.o -L../../lib/util -l${lib.bcvtb}"/>
</exec>
*****<exec executable="cl" failonerror="true" osfamily="windows" vmlauncher="false">*****
<arg line="f90client.obj ..\..\lib\util\${lib.bcvtb}.lib"/>
</exec>
</target>
Also, the output in the command line is shown in the attached image ("LINK: Fatal error LNK1561:entry point must be defined").
Is there any idea why is this happening?
thank you in advance.
Kind regards
