E+, How to model a AHU double fan
In my project, I have an AHU double fan (for air supply and return air), connected to a VRV. My purpose is to know the cooling capacity inside the room.
I would like to model only the AHU and see the impact of the AHU on my cooling capacity, if is it significant or not. My setpoint is 24C and I have 20 m3/h/pers. So, if I am not wrong, Basically, my AHU blows air in the room at 24 C because its connected to the VRV.
How can I do this easily in Energy plus ? With "Zoneventilation : design flow rate" and use "intake" ?
Thank for your help
Thank for your help
I would like to model only the AHU and see the impact of the AHU on my cooling capacity, if is it significant or not. My setpoint is 24C and I have 20 m3/h/pers. m3/h/pers.
So, if I am not wrong, Basically, my AHU blows air in the room at 24 C C, same than the inside temperature, because its connected to the VRV.
How can I do this easily in Energy plus ? With "Zoneventilation : design flow rate" and use "intake" ? Or with "HVAC templates : zone unitary " ?
Thank for your help
So, if I am not wrong, Basically, my AHU blows air in the room at 24 C, same than the inside temperature, because its connected to the VRV.
How can I do this easily in Energy plus ? With "Zoneventilation : design flow rate" and use "intake" ? Or with "HVAC templates : zone unitary " ? Or there is an example with AHU ?
Thank for your help
Thank for your help
Thank for your help
How can I do this easily in Energy plus ? With "Zoneventilation : design flow rate" and use "intake" ? Or with "HVAC templates : zone unitary " ? Or By chance, there is an example with AHU ?
Thank for your help
How can I do this easily in Energy plus ? With "Zoneventilation : design flow rate" and use "intake" ? Or with "HVAC templates : zone unitary " ? By chance, there is an example with AHU ?
Thank for your help
In my project, I have an AHU double fan (for air supply and return air), air) with a heat exchanger, connected to a VRV. My purpose is to know the cooling capacity inside the room.
Thank for your help
In my project, I have an AHU double fan (for air supply and return air) with a heat exchanger, connected to a VRV. My purpose is to know the cooling capacity inside the room.
Thank for your help
E+, How to model a AHU double fanfan (supply air and return air)
In my project, I have an AHU double fan (for air supply and return air) with a heat exchanger, exchanger with a cooling coil, connected to a VRV. My purpose is to know the cooling capacity inside the room.
So, if If I am not wrong, Basically, my AHU blows air in the room at 24 C, quite same than the inside temperature, because its connected to the VRV. VRV and has a heat exchanger.
Thank for your help
E+, How to model a AHU double fan (supply air and return air)
In my project, I have an AHU double fan (for air supply and return air) with a heat exchanger with and a cooling coil, connected to a VRV. VRF. My purpose is to know the cooling capacity inside the room.
If I am not wrong, Basically, my AHU blows air in the room at 24 C, quite same than the inside temperature, because its connected to the VRV and has a heat exchanger.
Thank for your help
In my project, I have an AHU double fan (for air supply and return air) with a heat exchanger and a cooling coil, connected to a VRF. My purpose is to know the cooling capacity inside the room.
Or with "HVAC templates : zone unitary " ? ? I have seen in the I/O reference, they model AHU with that one By chance, there is an example with AHU ?
Thank for your help
Or with "HVAC templates : zone unitary " ? I have seen in the I/O reference, they model AHU with that one one.
Thank for your help
In my project, I have an AHU double fan (for air supply and return air) with a heat exchanger and a cooling coil, connected to a VRF. My purpose is to know the cooling capacity inside the room. room, something like what follow : http://www.daikin.com.sg/product-series/vrv-ahu/
How can I do this easily in Energy plus ? With "Zoneventilation : design flow rate" and use "intake" "HVACTemplate:Zone:PTAC ? It seems to be quite close of what I would like.
Or with "HVAC templates : zone unitary " ? I have seen in the I/O reference, they model AHU with that one.
Thank for your help
