Hi I'm trying to model 4-pipe active beam system in openstudio and notice that there is a fourpipebeam terminal unit type in energyplus but not in openstudio (openstudio has cooledbeam only).
One option is to edit the idf file outside openstudio. But i'm wondering if there's any reason for openstudio to not include fourpipebeam and anything to watch out in the settings in energyplus.
The other option is to use the fourpipeindunit. From the inputs look like the water coil types and the terminal type (and underlying calcs) are different. So any tips or recommendations appreciated.
