When I run the AddIdealLoadsToAllZones measure in conjunction with IdealLoadsOptions, and put to true to use ventilation objects in the model, OS Server/PAT keeps failing and I can't figure out why. It seems to be an error in EnergyPlus run. Here is a link to the OSM file I'm using... https://www.dropbox.com/s/45reawg26vziea4/SPEEDTest1.osm?dl=0 Here is a link to the zip file for the user_data_point: https://www.dropbox.com/sh/msk9mgfr44ui55m/AAClNaBjbpVFze45AU0rjHhNa?dl=0
Attached are images of measure inputs and the OS server output log.C:\fakepath\Capture1.PNG(/upfiles/1535716217894088.png)(/upfiles/15357162099949041.png)
