I am doing an EnergyPlus simulation using the actual air-conditioning units of the building. The ACU's are window type therefore, I used the ZoneHVAC:WindowAirConditioner of the IDF and that also needs the data of the cooling coil to used. Now, I used the Cooling Coil DX Single Speed and I find it difficult on what values be inputted in the following: 1. Gross Rated Cooling Capacity 2. Gross Rated Heat Sensible Ratio 3. Rated Air Flow Rate
I would like to ask a help on how to solve this values or are there any constants to multiplied since I modeled an actual 2.5 horsepower ACU.
