I'm using the Honeybee interface to run EnergyPlus simulation for a simple model.
I got the following severe error:
Program Version,EnergyPlus, Version 8.9.0-eba93e8e1b, YMD=2018.08.12 11:34,
* Severe * <root>[Output:Variable][Output:Variable 76][reporting_frequency] - "Simple" - Failed to match against any enum values.
I checked the IDF file, and the format of the two output variables as highlighted below seems OK:
Output:Variable,*,Surface Outside Face Incident Ground Diffuse Solar Radiation Rate per Area,hourly;
Output:Diagnostics,DisplayExtraWarnings;
Output:SQLite, Simple;
Output:Variable,My_PV_generator_system:DISTRIBUTIONSYSTEM,Electric Load Center Produced Electric Energy, Simple;
Once these two output variables on diagnostics and SQLite as highlighted above are removed in the Honeybee workflow, the simulation runs correctly.
However, without removing these two output variables: 1. the same Honeybee workflow works fine in another computer with the same software installation, and 2. the same IDF file also works fine independently through the EPLaunch.exe.
May I ask if you can kindly advise what could have caused the severe error in this case?
