Hi!
I'm in a kind of trouble right now concerning a E+ data analysis, in terms of the Solar Radiation "Surface Outside Face Incident Beam Solar Radiation Rate per Area". After simulation I got the following xEso analysis, so the diagram shows a "U". After that I copied the data with ctrl + c to gather the dates with numbers in a excel sheet for visualization. But my Excel Diagram tool gave me a complete different course of the diagram, it's straight and not a "U". Even the maximum values are incorrect so I assume that it's a different data set that I copied. I've tried this several times and it worked well with the "Site Diffuse Solar Radiation Rate per Area" but not with the intended surface.
Unfortunately I am unable to show some pictures here right now.
Any advise? Thank you!
