Dear colleagues, I am trying to design and study the daylight inside a library. I have been working on the sketch with the OpenStudio Plugin but now a lot of errors and questions are appering:
My building is not perfectly aligned with the North so I set up in the "OS:Building" tab the correct North Axis (258º). Does this mean that I also need to input the same value on the "Direction of the Relative North" of tabs "OS:InteriorPartitionSurfaceGroup" and "OS:ShadingSurfaceGroup"?
Another issue that it is coming up is when I paste a lot of surfaces (around 53000). The building is composed by 3 similar rooms and I designed the first one expecting to copy and paste to get the other two but when I try to paste the following error appears:
"ERROR:
RuntimeError
C:\Git\OS\openstudiocore\src\utilities\idf\WorkspaceObject.cpp@836 : Attempt to write a disconnected WorkspaceObject out to Idf.
BACKTRACE:
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/interfaces/DrawingInterface.rb:552:in to_s'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/interfaces/DrawingInterface.rb:552:increate_from_entity_copy'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/interfaces/SurfaceGroup.rb:178:in create_from_entity_copy'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/interfaces/DrawingInterface.rb:532:innew_from_entity_copy'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/observers/SurfaceGroupEntitiesObserver.rb:387:in block in onElementAdded'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/PluginManager.rb:235:incall'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/PluginManager.rb:235:in block in process_events'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/PluginManager.rb:228:ineach'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/PluginManager.rb:228:in process_events'
C:/openstudio-2.6.0/SketchUpPlugin/openstudio/sketchup_plugin/lib/PluginManager.rb:287:inblock in start_event_processing'
SketchUp:1:in `call' "
My objective was to at least have the geometry converted to a Radiance file where I can do the image generation by myself on Radiance. Can someone help me with these issues? Thank you in advance for your time, Best regards, Nuno Saraiva
