this error message just started popping up recently when I added several Orientation optimzations to Optimization run. I am reporting to BeOpt team as instructed; can't deduce what problem source/fix is.
Message: The following application error has occurred in BEopt v2.8.0.0. Please report this to the BEopt development team and restart the application.
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
Stack Trace:
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List1.get_Item(Int32 index)
at NREL.BEopt.UICS.BEoptEnergySavingsChartControl.DrawOptionSensitivityLines(Points linePoint, Graphics3D g, Tuple4 t)
at NREL.BEopt.UICS.BEoptEnergySavingsChartControl.tChart1_AfterDraw(Object sender, Graphics3D g)
