Hi everybody, let's explain a bit the problem. With my research group we are trying to perform a Co-Simulation (through .idf FMU export) between Energy+ and Labview. The idea is to simulate the building model with E+ and emulate it in the laboratory. Outputs from the simulation should pass to the real HP. I would like to ask if someone implemented something similar because we are having problems.We are not able to overwrite "node Temperatures" and neither to implement a UserDefined component which would substitute the HP in the Energy+ model. I know that I explained it in a general way but I first would like to receive some feedback and then maybe ( I hope ) enter in the details. Thanks in advance! Paolo
