Hello, I am now trying to use parametric analysis tool for my OS model of a horticultural greenhouse. Because the floor of greenhouses made of soil and it is difficult to determine the parameters, I would like to vary parameters of soil material by using PAT and which parameter set will suite for the research site.
I think there's no measures to change the properties of material in BCL (if there is, I'd like to know it). So, I will prepare the measure for this.
Before that, I'd like to know about a point below; After changing the properties of material, will it be reflected to the seed model?
I'd be very glad if you give me any tips.
Thanks.
