OS 2.5.1 Baseline Measure
I am having further issues beyond what was discussed here and here with the OpenStudio 2.5.1 updates. The error says it is unable to find the eplusout.sql file in my local temp folder. I don't understand how this folder fits into the measure, but I do know the I have an eplusout.sql file in my run folder that seems to work fine though it is nearly 200 MB. Here is the error from the baseline measure log:
ERROR Results for the run couldn't be found here: C:/Users/timj/AppData/Local/Temp/OpenStudioApp.MS1964/ApplyMeasureNow/run/000_6c1da0f7-8c62-40b0-a0e2-d327568f89c5/output/SR1/run/eplusout.sql.
This is a fairly large model at 320k sf and 120 or so zones. The OSM runs, but takes over 3 hours with no major red flags that I can see. This particular ECM is a 2012 IECC code compliance model that needs to be adapted to 2010 Appendix G. I have my .osm located here for reference. It doesn't seem to matter if I apply the 2010 or 2013 measure.
Any help on this would be appreciated as I have struggled to get the baseline measure to run on these larger OpenStudio models.
