OpenStudio crashes when I drag and drop a measure. This crash only occurs after the .osm file has been edited in sketchup.
Can someone help me understand this error message? I tried to go to the path mentioned ( C:\Git\OS\openstudiocore\src\energyplus\ForwardTranslator\CreateAirLoopHVACSupplyPath.cpp ) but it doesn't exist on my computer.
Measure Manager has crashed
Measure Manager has crashed, attempting to restart
[2018-06-01 23:30:07] INFO WEBrick 1.3.1
[2018-06-01 23:30:07] INFO ruby 2.2.4 (2015-12-16) [x64-mswin64_120]
[2018-06-01 23:30:07] INFO WEBrick::HTTPServer#start: pid=7672 port=51266
Barracuda-PC - - [01/Jun/2018:23:35:41 Pacific Daylight Time] "POST /bcl_measures HTTP/1.1" 200 17550 - -> /bcl_measures
Barracuda-PC - - [01/Jun/2018:23:35:43 Pacific Daylight Time] "POST /update_measures HTTP/1.1" 200 2 - -> /update_measures
Barracuda-PC - - [01/Jun/2018:23:36:13 Pacific Daylight Time] "POST /bcl_measures HTTP/1.1" 200 17550 - -> /bcl_measures
Barracuda-PC - - [01/Jun/2018:23:36:13 Pacific Daylight Time] "POST /update_measures HTTP/1.1" 200 2 - -> /update_measures
[BOOST_ASSERT] <2> Assertion splitters.size() == 1u failed on line 70 of class boost::optional<class openstudio::idfobject=""> __cdecl openstudio::energyplus::ForwardTranslator::createAirLoopHVACSupplyPath(const class openstudio::model::Node &) in file C:\Git\OS\openstudiocore\src\energyplus\ForwardTranslator\CreateAirLoopHVACSupplyPath.cpp.
[utilities.bcl.BCLXML] <2> 'C:/Users/saroop/BCL/67931e1a-bff1-4da2-97c9-577f0daecc40/775c82e9-e9c5-49d1-95c3-ecd79be30851/measure.xml' does not exist
[utilities.bcl.BCLMeasure] <2> 'C:/Users/saroop/BCL/67931e1a-bff1-4da2-97c9-577f0daecc40/775c82e9-e9c5-49d1-95c3-ecd79be30851' is not a measure
[openstudio.model.CoilCoolingWater] <1> Required availability schedule not set, using 'Always On' schedule [openstudio.model.CoilCoolingWater] <1> Required availability schedule not set, using 'Always On' schedule [openstudio.model.CoilCoolingWater] <1> Required availability schedule not set, using 'Always On' schedule [openstudio.model.CoilCoolingWater] <1> Required availability schedule not set, using 'Always On' schedule [openstudio.model.CoilCoolingWater] <1> Required availability schedule not set, using 'Always On' schedule [openstudio.model.CoilCoolingWater] <1> Required availability schedule not set, using 'Always On' schedule
