According to the answer from previous question, I want to remove the construction from Surfaces in order construction set specified in Story to be used.
What I come up is to going through all surfaces, if the construction type is specified one, they remove the construction from that surface refer to image below.
However, when I look at the OpenStudio SDK, I cannot find construction method in surfaces.
Does anyone know how I can specify the construction which is applied to the surfaces?
