Openstudio-Measure about Adding R-value of Insulation for Ceiling for PAT
I simulated an one level residential house with a horizontal ceiling. I tried to create a measure about adding R-Value of Insulation for Ceiling by modifying the existing measure "Increase R-value of Insulation for Roofs to a Specific Value". I replaced the word "roof" to "ceiling" in the measure and change the Outside Boundary Condition from "Outdoor" to "Surface". (It succeed when I modified "Increase R-value of Insulation for External Walls to a Specific Value" to Floor)
I ran the new measure in PAT, but it's failed with initial condition:" The building had 1 Ceiling constructions: Ceiling (R-19.9)". Is that because the material of floor in the roof zone has to be changed at the same time as they are the same material? If so, how to do that?
The created measure file for ceilings and original downloaded measure file for roofs are in the below link: https://www.dropbox.com/sh/3dqbiw58drdg83a/AABDocE2CAP5yrbMjqL4vJZca?dl=0
The created measure file for ceilings and original downloaded measure file for roofs are in the below link: https://www.dropbox.com/sh/3dqbiw58drdg83a/AABDocE2CAP5yrbMjqL4vJZca?dl=0 hosted here.
The created measure file for ceilings and original downloaded measure file for roofs are hosted here.
