Lately I was upgrading to OS 2.5.0 which uses E+ 8.9. When I try to run one of my models which use to run smoothly in OS 2.4.0 it failed with the following massage:
Program Version,EnergyPlus, Version 8.9.0-eba93e8e1b, YMD=2018.05.07 20:08,
** Severe ** <root>[Schedule:Day:Interval][2BHDO Default][interpolate_to_timestep] - "yes" - Failed to match against any enum values.
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
I am changing the Schedule:Day:Interval's interpolate_to_timestep property to yes with a measure I wrote since OS will not expose it.
Since it is a Yes or yes enum issue I would guess it will affect many other things.
Has anyone experienced such a warning?
