Hello,
I am getting an error "Too many fields for object:Schedule Compact" when trying to open a idf file that was exported using OS v2.5.0 . I used a measure (courtesy of Lyle keck, for sharing the measure) to bring in 8760 hourly data and assigned it to load profile plant object.
One of the discussion threads suggested that adding more lines to "Energy+idd file" would help resolve the issue. However, I didn't quite understand what piece of text to add to the idd file. Any input on this would be helpful.
My goal is to ultimately open the file using IDF editor and attempt to add more customization on the plant loop.
Attached is the idf file.
Thank you, -Aditya
