I am trying to use WWR measure in PAT, but a warning appears:
IP: IDF line 307 Error detected in Object=FENESTRATIONSURFACE:DETAILED, named=SUB SURFACE 1, Field [Construction Name] is required but was blank.
I have a seed model that runs successfully in openstudio alone. A seed model have a construction name Okno:
Why is this field blank all of a sudden?
PAT local results:
How can i fix this warrning?
I am using OS 2.4.
