Hi guys,
I am trying to model the shading around the windows in the openstudio sketchup plugin. Is there a way to do this in the form of a shading component instead of a shading group? Otherwise it will be impossible to test different shading types because i would have to change this manually in the model around each window.
I tried to add a shading group in a component but the shading zones apparantly have to be added at the top level of the sketchup model.
Has anyone had the same problem and maybe found a solution?
