Hello,
I am using the following the pluggin Euclide for Sketchup to run building energy simulations using Energy Plus. But when I try to load the climate file, the following message appears with Sketchup 2018 and even with Sketchup 2017. Could you help me to solve this?
ERROR: ArgumentError invalid byte sequence in UTF-8
BACKTRACE:
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/WeatherFile.rb:33:in split'
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/WeatherFile.rb:33:inparse_header'
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/WeatherFile.rb:18:in initialize'
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/dialogs/RunSimulationDialog.rb:95:innew'
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/dialogs/RunSimulationDialog.rb:95:in show_weather_file_info'
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/dialogs/RunSimulationDialog.rb:87:inon_browse'
C:/Users/F3159470/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/dialogs/RunSimulationDialog.rb:27:in block in add_callbacks'
SketchUp:1:incall'
CONFIGURATION: Euclid 0.9.3 SketchUp 17.2.2555 64-bit Pro Ruby 2.2.4 x64-mingw32
