Hi everyone !
I really need some help here about the Chiller:EIR component in EnergyPlus. I've tried to go read the engineering references but I still don't get it.
I'm using an electric air-cooled chiller to model an air to water heat pump in cooling mode.
My problem is that the part load ratio won't ever reach 1. Even if my PLR max is 1, the chiller capacity is blocked at rated capacity. I've tried to change the maximum PLR, then the evaporator cooling rate will be blocked at maxPLR*rated capacity but it feels wrong to put a max PLR higher than 1, that's not what supposed to happen.
A little screenshot to help you understand my problem :
In this exemple the rated capacity is 9050W, when the cycling ratio is 1 the chiller should be working at full capacity (~10500 as it's my capacity multiplier*rated capacity) but it won't. I've tried to completely suppress any cycling by puting the min PLR and unloading ratios at 0, but it won't work either.
My question is : To reflect the real operation (What's really going on), what should I do? Am I not looking at the right outputs? To me, it looks like the max PLR should actually be 1, should I adjust the maximum PLR in the object so it's actually the case or is it wrong? Is there an other way?
I hope you'll be able to give me some insight, I really need some help to get that so all my results are'nt false...
Thanks a lot for reading and have a good day !
Regards
Mary
