Hello all,
I've tried to simulate a building with the "AedgOfficeHvacRadiantDoas" Measure. When I run the simulation I get this error. I've tried several solutions I've found on this forum but none work. Does anyone have the possible answer for me?
* Severe * IP: IDF line~4479 Object=CONTROLLER:MECHANICALVENTILATION, name=CONTROLLER MECHANICAL VENTILATION 1, Required Field=[Zone 1 Name] was blank.
* Severe * IP: IDF line~4863 Object=CONTROLLER:MECHANICALVENTILATION, name=CONTROLLER MECHANICAL VENTILATION 2, Required Field=[Zone 1 Name] was blank.
* Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details. * ~~~ * Possible Invalid Numerics or other problems * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=2 ..... Last severe error=IP: IDF line~4863 Object=CONTROLLER:MECHANICALVENTILATION, name=CONTROLLER MECHANICAL VENTILATION 2, Required Field=[Zone 1 Name] was blank.
