ASHRAE 90.1-2013 in Section 11.5.2 specifically accounts for packaged unit COP adjustment if the supply air fan is modeled as part of the air loop, as opposed to the HVAC unit itself, as its the case many times. I have not come across something equivalent for 2015 IECC. Does one just use the COP from Tables 6.8.1-1 through 6.8.1-4? Or should one apply the methodology from ASHRAE 90.1-2013 to 2015 IECC?
