Hello everyone, I want to know if the least version of BCVTB (version 1.6) support the co-simulation with Energyplus 8.8. From the manual of BCVTB 1.6, it states that the BCVTB is tested with energuplus 8.5 or lower versions and all the examples files of BCVTB use the Energyplus 8.5 or lower versions. I have tried to upgrade one of the idf file of version 8.5 in the BCVTB example to version 8.8. After the upgrade, the co-simulation does not work. I am not sure this is due to BCVTB does not support Eplus 8.8 or somethong went wrong with my seeting. Can any experienced person can confirm if BCVTB works with Energyplus 8.8? I will be grateful if someone can give me comments.
