After upgrading to OS 2.3.0 it seems that the Zone Report Measure can't anymore collect the data it needs. I think it is something that changed in E+ 8.8.0 but I am not sure what it is. The measure reports the following warnings when run against the test OSM file supplied with it:
Applying ZoneReport
Result: Success
Final Condition: Successfully finished writing 'Zone Report'.
Warn: Could not get data for LightingSummary Entire Facility Interior Lighting Extreme Tstat Zone% Lighting Power Density.
Warn: Could not get data for LightingSummary Entire Facility Interior Lighting Extreme Tstat Zone% Full Load Hours/Week.
Warn: Could not get data for HVACSizingSummary Entire Facility Zone Heating Extreme Tstat Zone User Design Load.
Warn: Could not get data for HVACSizingSummary Entire Facility Zone Heating Extreme Tstat Zone User Design Air Flow.
Warn: Could not get data for HVACSizingSummary Entire Facility Zone Cooling Extreme Tstat Zone User Design Load.
Warn: Could not get data for HVACSizingSummary Entire Facility Zone Cooling Extreme Tstat Zone User Design Air Flow.
Warn: Could not get data for HVACSizingSummary Entire Facility Zone Cooling Extreme Tstat Zone Date/Time Of Peak.
Warn: Could not get data for HVACSizingSummary Entire Facility Zone Heating Extreme Tstat Zone Date/Time Of Peak.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Gas InteriorEquipment:Gas:Zone:Extreme Tstat Zone Electricity Annual Value.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Electricity InteriorEquipment:Electricity:Zone:Extreme Tstat Zone Electricity Annual Value.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Gas InteriorEquipment:Gas:Zone:Extreme Tstat Zone Gas Maximum Value.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Gas InteriorEquipment:Gas:Zone:Extreme Tstat Zone Timestamp of Maximum.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Electricity InteriorLights:Electricity:Zone:Extreme Tstat Zone Timestamp of Maximum.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Electricity InteriorEquipment:Electricity:Zone:Extreme Tstat Zone Electricity Maximum Value.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Electricity InteriorEquipment:Electricity:Zone:Extreme Tstat Zone Timestamp of Maximum.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Other InteriorEquipment:DistrictHeating:Zone:Extreme Tstat Zone Annual Value.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Other InteriorEquipment:DistrictHeating:Zone:Extreme Tstat Zone Maximum Value.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Other InteriorEquipment:DistrictHeating:Zone:Extreme Tstat Zone Timestamp of Maximum.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Other Heating:EnergyTransfer:Zone:Extreme Tstat Zone Timestamp of Maximum.
Warn: Could not get data for EnergyMeters Entire Facility Annual and Peak Values - Other Cooling:EnergyTransfer:Zone:Extreme Tstat Zone Timestamp of Maximum.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components People Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Lights Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Equipment Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Refrigeration Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Water Use Equipment Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components HVAC Equipment Losses Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Power Generation Equipment Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Infiltration Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Zone Ventilation Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Interzone Mixing Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Exterior Wall Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Interzone Wall Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Ground Contact Wall Total.
Warn: Could not get data for ZoneComponentLoadSummary EXTREME TSTAT ZONE Estimated Heating Peak Load Components Other Wall Total.
This is just the beginning of a long list of warnings. Any idea what was changed?
