Hello everyone,
i am currently modelling a desiccant cooling system using Energyplus. After i built the model and runned the simmulation, i found some problems on the componnet of heat exchanger in the system.The main air stream leaving the desiccant wheel enter the Heat exchanger as primary flow to cool down its temperature. The Secondary air flow of the heat exchanger is outside air, so i put a variable fan on the path of the secondary flow.
After running the simulation, i found the the air temperature of primary air flow at the inlet and outlet of Heat exchanger is equal and the air mass flow rate at the outside air node (inlet node of the secondary air flow) was zero.
I checked the error report and found the relevant warning information about the outside air node, just showing below:
It says the connection of the outside air node is not correct. In my model, i just creasted a outdoor node list and put this outside air node on the list and i have nothing operation of this node on other place.
So can anyone give me some idea on this issue, many thanks!
