Hi Everyone
I'm currently trying to run some design alternatives in OS Parametric Analysis Tool (PAT) v2.1 and I've run into a 'OSA export error' when I try to simulate any of the measures. The error indicates that "you need at least 1 variable set on the analysis tab in order to run the analysis." I'm unclear of the exact cause of this error or where it is occurring. I've checked all of the measure options to see if anything seems out of place. Has anyone else run into this issue and if so how was it resolved? Appreciate any feedback and thoughts on this.
