Program Version,EnergyPlus, Version 8.8.0-7c3bbe4830, YMD=2017.12.02 20:49,IDD_Version 8.8.0
* Severe * IP: IDF line~102 Did not find "ProgramControl" in list of Objects
*** IDF Context for following error/warning message:
*** Note -- lines truncated at 300 characters, if necessary...
*** 1051 ZoneHVAC:IdealLoadsAirSystem, Block1:Zone1 Ideal Loads Air, !- Ideal Loads Air Name
*** Only last 8 lines before error line shown.....
*** 1052 , !- Availability Schedule Name
*** 1053 Node Block1:Zone1 In, !- Zone Supply Air Node Name
*** 1054 , !- Zone Exhaust Air Node Name
*** 1055 35, !- Maximum Heating Supply Air Temperature {C}
*** 1056 12, !- Minimum Cooling Supply Air Temperature {C}
*** 1057 0.0156, !- Maximum Heating Supply Air Humidity Ratio {kg-H2O/kg-air}
*** 1058 0.0077, !- Minimum Cooling Supply Air Humidity Ratio {kg-H2O/kg-air}
*** 1059 LimitCapacity, !- Heating Limit
* Severe * IP: IDF line~1059 Invalid Number in Numeric Field#4 (Minimum Cooling Supply Air Humidity Ratio), value=LIMITCAPACITY,
in ZONEHVAC:IDEALLOADSAIRSYSTEM=BLOCK1:ZONE1 IDEAL LOADS AIR
* Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details.
* ~~~ * Version in IDF="8.5.0.001" not the same as expected="8.8"
* ~~~ * Possible Invalid Numerics or other problems
* Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=2
