I've downloaded the OpenStudio 2.3 with EnergyPlus 8.8 and SketchUp 2017. I created a model and when I want to export the idf file from SketchUp OpenStudio plugin, It doesn't let me to do that. I tried to Launch the openstudio first and then export the IDF file. However when I run the OSM model, the simulation fails and I get this error C:\fakepath\123.JPG
"utilities.idf.WorkspaceObject] <2> Attempt to write a disconnected WorkspaceObject out to Idf.
[16:13:26.410201 ERROR] Found error in state 'translator' with message
["E:\Git\OS1\openstudiocore\src\utilities\idf\WorkspaceObject.cpp@835 : Attempt to write a disconnected WorkspaceObject out to Idf.::/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/model.rb:66:in translateModel'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/model.rb:66:intranslate_to_energyplus'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_translation.rb:54:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in run'\n:/openstudio_cli.rb:804:inexecute'\n:/openstudio_cli.rb:620:in execute'\n:/openstudio_cli.rb:1517:in<main>'\neval:85:in eval'\neval:85:inrequire_embedded_absolute'\neval:70:in block in require'\neval:64:ineach'\neval:64:in require'\neval:2:in<main>'"]}
Any idea?
