I'm trying to add a series of Illuminance Maps and daylighting control objects into select zones using OpenStudio v2.2.0 via the Sketchup plugin. This is working in most of my zones, but the x- and y- coordinates and x- and y- lengths keep shifting or resizing on several of the Illuminance Map objects after I reload the model. I am unable to figure out whats triggering this or why its happening in certain zones but not others. This may be unrelated, but the Radiance measure will simulate at this point but no Radiance output reports are produced (only EPlus). I have successfully used the Radiance measure before so I'm fairly confident its setup correctly but I could be missing something simple here. Any thoughts as to whats causing these objects to shift around and automatically resize?
