fluid type in EnergyPlus
Hi! I want to make a plant loop consisting of [WaterHeater:Mixed] and [Boiler:Steam] At [PlnatLoop] class list, I entered 'Steam' at fluid type and then an error occurred. Error message said,
* Severe * Existing Fluid type for node, incorrect for request. Node=STEAM BOILER PLANT STEAM SUPPLY OUTLET NODE * ~~~ * Existing Fluid type=Steam, Requested Fluid Type=Water So I I entered 'Water' at fluid type and then an error occurred because of the similar reason. (fluid type is incorrect at [WaterHeater:Mixed] connected nodes.)
I think I need to make flude type which is water below 100 degree Celcius, and turn into steam above 100 degree Celcius at Group [FluidProperties]. Am I right? I've tried copy lists from [FluidPropertiesFefData.idf] but it didn't work. Help me if anybody knows how to solve this problem!!
Hi! I want to make a plant loop consisting of [WaterHeater:Mixed] and [Boiler:Steam] [Boiler:Steam].
At [PlnatLoop] class list, I entered 'Steam' at fluid type and then an error occurred. occurred.
Error message said,
* Severe * Existing Fluid type for node, incorrect for request. Node=STEAM BOILER PLANT STEAM SUPPLY OUTLET NODE * ~~~ * Existing Fluid type=Steam, Requested Fluid Type=Water Type=Water
I think I need to make flude type which is water below 100 degree Celcius, and turn into steam above 100 degree Celcius at Group [FluidProperties]. [FluidProperties].
Hi! I want to make a plant loop consisting of [WaterHeater:Mixed] and [Boiler:Steam].
Error message said,
Am I right? I've tried copy lists from [FluidPropertiesFefData.idf] [FluidPropertiesRefData.idf] but it didn't work. Help me if anybody knows how to solve this problem!!
Error message said,
Am I right? I've tried copy lists from [FluidPropertiesRefData.idf] but it didn't work. Help me if anybody knows how to solve this problem!!
Hi! I want to make a plant loop consisting of [WaterHeater:Mixed] and [Boiler:Steam].WaterHeater:Mixed and Boiler:Steam.
At [PlnatLoop] PlantLoop class list, I entered 'Steam' at fluid type and then an error occurred.
Error message said,
** Severe  * ** Existing Fluid type for node, incorrect for request. Node=STEAM BOILER PLANT STEAM SUPPLY OUTLET NODE
   * **   ~~~   * ** Existing Fluid type=Steam, Requested Fluid Type=Water
Type=Water
So I I entered 'Water' at fluid type and then an error occurred because of the similar reason. (fluid type is incorrect at [WaterHeater:Mixed] WaterHeater:Mixed connected nodes.)
I think I need to make flude fluid type which is water below 100 degree Celcius, Celsius, and turn into steam above 100 degree Celcius at Group [FluidProperties].FluidProperties.
Am I right? I've tried copy lists from [FluidPropertiesRefData.idf] FluidPropertiesRefData.idf but it didn't work. Help me if anybody knows how to solve this problem!!
Hi! I want to make a plant loop consisting of WaterHeater:Mixed and Boiler:Steam.
At PlantLoop class list, I entered 'Steam' at fluid type and then an error occurred.
Error message said,
** Severe  ** Existing Fluid type for node, incorrect for request. Node=STEAM BOILER PLANT STEAM SUPPLY OUTLET NODE
   **   ~~~   ** Existing Fluid type=Steam, Requested Fluid Type=Water
So I I entered 'Water' at fluid type and then an error occurred because of the similar reason. (fluid type is incorrect at WaterHeater:Mixed connected nodes.)
I think I need to make fluid type which is water below 100 degree Celsius, and turn into steam above 100 degree Celcius at Group FluidProperties.
Am I right? I've tried copy lists from FluidPropertiesRefData.idf but it didn't work. Help me if anybody knows how to solve this problem!!
