radiance rvu.exe error
I'm trying to use rvu.exe but it can't run and gives the following error image description
I'm using Radiance v5.1 and Windows 7 Enterprise 64bit. I tried to use it in cmd and/or double click the exe file in the bin folder. Both cases show this error. I also tried it on another computer, still same problem.
Am I using it in a wrong way or is it something with my system setting? Thanks.
