I'm running into a fatal error with the Tariff Selection Time and Date Dependent measures in OpenStudio 2.2.0, exact error text copied below. None of the "Tariff Selection Time and Date Dependent..." measures work, all of them throw this error. They all work in OS 1.1X versions without issue.
Applying TariffSelectionTimeAndDateDependentWithMaximumDemandCharge
Result: Fail
Error: E:\Git\OS1\openstudiocore\src\measure\OSArgument.cpp@306 : Argument peak_start_hour has no value.
C:/Users/xxxx/AppData/Local/Temp/OpenStudioApp.vU7180/resources/measures/TariffSelectionTimeAndDateDependentWithMaximumDemandCharge 1 1/resources/os_lib_helper_methods.rb:143:in valueDisplayName'
C:/Users/xxxx/AppData/Local/Temp/OpenStudioApp.vU7180/resources/measures/TariffSelectionTimeAndDateDependentWithMaximumDemandCharge 1 1/resources/os_lib_helper_methods.rb:143:inblock in checkDoubleAndIntegerArguments'
C:/Users/xxxx/AppData/Local/Temp/OpenStudioApp.vU7180/resources/measures/TariffSelectionTimeAndDateDependentWithMaximumDemandCharge 1 1/resources/os_lib_helper_methods.rb:138:in each'
C:/Users/xxxx/AppData/Local/Temp/OpenStudioApp.vU7180/resources/measures/TariffSelectionTimeAndDateDependentWithMaximumDemandCharge 1 1/resources/os_lib_helper_methods.rb:138:incheckDoubleAndIntegerArguments'
C:/Users/xxxx/AppData/Local/Temp/OpenStudioApp.vU7180/resources/measures/TariffSelectionTimeAndDateDependentWithMaximumDemandCharge 1 1/measure.rb:213:in run'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:452:inapply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_ep_measures.rb:41:inperform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun'
:/openstudio_cli.rb:804:in execute'
:/openstudio_cli.rb:620:inexecute'
:/openstudio_cli.rb:1517:in <main>'
eval:85:ineval'
eval:85:in require_embedded_absolute'
eval:70:inblock in require'
eval:64:in each'
eval:64:inrequire'
eval:2:in `<main>'
Failed.
Any suggestions welcome, thanks!
