I'm new in HVAC system, and when I set an ideal HVAC system in energyplus, the output only shows the Zone Air System Sensible Cooling Rate, all the Sensible Heating Rate are zero, if I want to know the heating rate, what should I do ?
![]() | 1 | initial version |
![]() | 2 | retagged |
