Hi, I'm modeling a Leed Baseline model.
The original buiding has a wide unconditioned roof. Should I consider it as a shading surface? Should I delete al the unconditionated roof in the baseline model?
| 1 | initial version |
| 3 | retagged |
The original buiding has a wide unconditioned roof. Should I consider it as a shading surface? Should I delete the unconditionated roof in the baseline model?
| 4 | retagged |
Hi,
The original buiding building has a wide unconditioned roof. Should I consider it as a shading surface?
Should I delete the unconditionated unconditioned roof in the baseline model?
