I have successfully added a ZoneHVAC:Baseboard:Convective:Water
and had success with heating. Next, I would like to add the ZoneHVAC:CoolingPanel:RadiantConvective:Water
component to a thermal zone so that I can use a cold water source to offset cooling loads for the space. I am attempting to use this component as a simplified chilled beam or radiant cooling floor.
However, I have been unable to find the ZoneHVAC:CoolingPanel:RadiantConvective:Water
component in OpenStudio. Does anyone have any recommendations on how to add this component?
Are there alternative methods I could use to supply cooling to a space when I have a cold water loop? I am using a PlantComponent:TemperatureSource
to add a cool water source to OpenStudio from an external source. Could a chilled beam system work with low grade cool water?
