Hi All
Am trying to analyse a commercial space in energyplus am using sketchup make for drawing the space and euclid extension for creating zones, everything goes well when i save the file, but once i open the file again to continue my work it is show euclid error and am unable to create the other zones...
The error is as follows: Sorry...the Euclid extension has encountered an error. This error may cause unpredictable behavior in the extension--continue this session with caution! It would probably be a good idea to exit SketchUp and start again.
For help, please email us at info@bigladdersoftware.com.
When reporting a problem, please copy the information below into your email (scroll down):
ERROR: NoMethodError undefined method `new_unique_object_name' for nil:NilClass
BACKTRACE:
C:/Users/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:26:in create_input_object'
C:/Users/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/tools/NewZoneTool.rb:37:inonLButtonUp'
CONFIGURATION: Euclid 0.9.3 SketchUp 17.2.2555 64-bit Ruby 2.2.4 x64-mingw32
How to rectify it because the space is big and it is not possible to do it in an single day how to rectify it plzzz.....
Thank you in advance.....
